[Qgis-user] qgis random points in layer bounds not all points created
Newcomb, Doug
doug_newcomb at fws.gov
Fri Jan 10 08:33:17 PST 2020
Newcomb, Doug wrote
>>* I have 81 points that I buffer by 25m. I then run the random points in
*>>* layer bounds tool to generate 100 points. I get 43 and a message that not
*>>* all points were created.
*>>* I ask for 300 points, and I get 160 .
>The algorithm tries to randomly place each point for up to 200 attempts. So,
>more points to be created, more attempts.
>Obviously, did you specify the same minimum distance value in both your test
>for 100 and 300 points?
>The chance to place the whole number of requested points depends on the
>geometric characteristics of the polygons ad how are distributed in the
>space and the constraint of the minimum distance between each point. If this
>value is too large (e.g. in your case, > 50 m) then the problem may have no
>solution.
>By the way, it seems to me that the description of the algorithm in the user
>manual is not accurate and should be improved.
>It states that the tool creates random points within the _extent_ of a given
>layer, but it is not so.
>Regards.
>Andrea
Andrea,
Thank you. Double checking the minimum distance got me on the right track.
One thing to note. I used the buffer layer to clip a soil polygon
layer that was multipart. The clipped layer needed to be converted to
single part to place a single point in each polygon derived from the
buffered layer clip.
Are there any plans to make the number of tries to be a user
accessible variable in the GUI?
Doug
Doug Newcomb - Cartographer
USFWS
551F Pylon Dr
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb at fws.gov
*NOTE: This email correspondence and any attachments to and from this
sender is subject to the Freedom of Information Act (FOIA) and may be
disclosed to third parties.*
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200110/cacd5987/attachment.html>
