[Qgis-user] Micro-Geometry Problems
Hernán De Angelis dhdeangelis at comhem.se
Tue Jan 14 23:26:27 PST 2020
Steve,
In my opinion this is where GRASS topological vector model shines. One
suggestion would be to import these vectors into a GRASS location and
let GRASS clean the polygons and fix the topology automatically during
import. My experience with similar problems is that after the import and
cleaning there would be few if any errors of the sort you mention. In
the worst case any surviving error is found it could in principle be
solved by deleting the stubborn surface and digitizing it again. It will
definitely not take two weeks of work!
Good luck!
H.
On 2020-01-14 22:51, smiller192 at cfl.rr.com wrote:
> All-
> I have digitized a land use/land cover layer as individual polygons.
> The snap options were used and, for most vertices, the snap was
> precise.  A vertex in polygon A has a precise match to a vertex in
> neighboring polygon B.
> But in 582 out of 2799 polygons, there are mis-matches in adjoining
> vertices that are only evident if you zoom into the layer at a
> magnification (i.e., a scale) of from 20000:1 to 40000 to 1.  I have
> spent a couple of weeks trying to remedy these by hand using the
> Vertex Tool and other means.  My question is this: is there an
> automated way in QIS to detect and remedy these situations?
> Thanks,
> Steve Miler
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200115/42e650a9/attachment.html>
