[Qgis-user] Micro-Geometry Problems
Gabriel De Luca
pablogabrieldeluca at gmail.com
Wed Jan 15 11:23:59 PST 2020
About how to remedy these situations, you can use the v.clean GRASS
provider algorithm, selecting the snap cleaning tool.
Kind Regards,
Gabriel
El mié., 15 de ene. de 2020 a la(s) 16:10, Gabriel De Luca (
pablogabrieldeluca at gmail.com) escribió:
> When digitizing, coordinates are taken from the canvas and stored to the
> layer. If the canvas (project) CRS is not the same as the layer CRS, a
> transformation and/or conversion must be done between the taken and stored
> coordinates. That transformation and/or conversion performed between the
> previous vertex to be rendered, and the rendered coordinate digitized to be
> stored, may lead a round trip error.
> If you are digitizing from a canvas CRS to the same layer CRS, and
> snapping to vertex, I think that you will not see any difference between
> both vertices.
> If you are snapping to intersections, you can see a difference also
> working in the same CRS for the canvas and the layer, because an
> intersection calculated coordinate may not be a rational number and at some
> decimal place it must be truncated.
> I don't know if any rendering option could truncate the coordinate of a
> vertex when rendering it, so when snapping to that vertex (in the same CRS
> for the canvas and the layer) could return a truncated coordinate for the
> digitized vertex.
> El mar., 14 de ene. de 2020 a la(s) 18:59, <smiller192 at cfl.rr.com>
> escribió:
>> All-
>> I have digitized a land use/land cover layer as individual polygons. The
>> snap options were used and, for most vertices, the snap was precise. A
>> vertex in polygon A has a precise match to a vertex in neighboring polygon
>> B.
>> But in 582 out of 2799 polygons, there are mis-matches in adjoining
>> vertices that are only evident if you zoom into the layer at a
>> magnification (i.e., a scale) of from 20000:1 to 40000 to 1. I have spent
>> a couple of weeks trying to remedy these by hand using the Vertex Tool and
>> other means. My question is this: is there an automated way in QIS to
>> detect and remedy these situations?
>> Thanks,
>> Steve Miler
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200115/5fd947c8/attachment.html>
