[Qgis-user] Fwd: MacOS project saving issue
Aldo Piombino aldo.piombino at tiscali.it
Sat Jan 18 23:48:30 PST 2020
Hi Eric
For this issue the right plugin for you is  “ Autoserver”: this plugin save the project every fixed time, perhaps ten minutes but I’m not sure of this timing
luckily, I have nad no needing to use it, but I think that you have only to rename the file nameproject.bak in project2.qgz
Aldo
Dr. Aldo Piombino
Scienzeedintorni: www.aldopiombino.blogspot.it <http://www.aldopiombino.blogspot.it/>  <http://www.aldopiombino.blogspot/>
Skype: aldo.piombino
> Inizio messaggio inoltrato:
> Da: "Fielding, Eric J (US 329A)" <eric.j.fielding at jpl.nasa.gov>
> Oggetto: [Qgis-user] MacOS project saving issue
> Data: 18 gennaio 2020 19:35:25 CET
> A: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> Sometimes I leave QGIS running for several days on a MacOS machine, adding extra layers, etc. If I forget to save at the end of each day, I often find the next day that I can’t save the project changes because some temporary file under /private/var/tmp no longer exists. I think there must be something in MacOS (or other software on my machine) that cleans up the temporary folders.
> Has anybody else seen this problem? Have you found a solution?
> Thanks,
>                 ++Eric
> Pasadena, California, USA
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200119/95f25967/attachment.html>
