[Qgis-user] Attribute Assistant
Richard McDonnell richard.mcdonnell at opw.ie
Wed Jan 22 01:09:37 PST 2020
Hi Ed,
In addition to what Matthias said, there is also Virtual Fields an example of them can be seen here
https://www.northrivergeographic.com/archives/qgis-2-6-virtual-fields
http://changelog.kartoza.com/en/qgis/section/expressions-23/print/149/
I believe this may be of some help. Note Virtual fields are not saved as part of the Layer, but as Part of the active project. You could though make them permanent when you’re finished, by creating a new field and using the virtual field as the source.
Hope this helps,
Richard.
Richard McDonnell MSc GIS, FME Certified Professional
FRM Data Management
Oifig na nOibreacha Poiblí
Office of Public Works
Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 1 647 6543
https://www.opw.ie
To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer: https://www.opw.ie/en/disclaimer/
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Matthias Kuhn
Sent: 21 January 2020 20:32
To: Ed Hawkins <elh1964 at gmail.com>; Qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Attribute Assistant
Hi Ed,
I must acknowledge my complete lack of the ESRI tools, so I am left with the first hits I find in an internet search to guess what it does exactly.
My first guess is, that "default value" configuration is what you are looking for. There is support for QGIS expressions - which opens up a wide variety of possibilities.
Matthias
https://gis.stackexchange.com/a/211154/9839
On 1/21/20 8:44 PM, Ed Hawkins wrote:
ESRI has a tool called attribute assistant for automatically populating attributes based on certain criteria that can be set up for certain methods is there such a tool for QGIS?
Ed Hawkins
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200122/3e20053c/attachment.html>
