[Qgis-user] Anyone use UK Watsonian vice counties?
Michael.Dodd michael.dodd at open.ac.uk
Mon Jan 27 07:57:35 PST 2020
Someone else has suggested an updated source here:
: https://github.com/BiologicalRecordsCentre/vice-counties
Am currently checking those polygons and so far they seem ok, they note there was an issue with the earlier version that I had been using, so the issue may now be solved.
Thanks
-----Original Message-----
From: Jonathan Moules <jonathan-lists at lightpear.com>
Sent: 27 January 2020 15:54
To: Michael.Dodd <michael.dodd at open.ac.uk>; 'qgis-user at lists.osgeo.org' <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] Anyone use UK Watsonian vice counties?
CAUTION: This mail comes from outside the University. Please consider this before opening attachments, clicking links, or acting on the content.
We're possibly talking at cross purposes.
I didn't follow the NBN link on that page, but instead used the the WFS URL ( http://geo.vliz.be:80/geoserver/wfs ) it provides which I connected to with QGIS and then added the Watsonian layer.
I suggested it because it may work for your purposes where your current dataset does not.
On 2020-01-27 15:47, Michael.Dodd wrote:
> Unfortunately that link goes back to NBN and a page that no longer exists so presumably it is the same dataset.
> Qgis gives various errors depending on the analysis but always with those 8 VC's, when trying 'check validity' it says there is a problem with self intersection. Not sure how to fix this as it is not obvious when you zoom in on the polygons.
> Sent: 27 January 2020 15:41
> Hi Michael,
> There is a WFS with them in that works in QGIS:
> https://www.geoseer.net/rl.php?ql=f64d2064355b5bdb&p=1&q=watsonian
> Not tried them for analysis or exporting them, but may be worth a try.
> Cheers,
> Jonathan
> On 2020-01-27 15:12, Michael.Dodd wrote:
> I have downloaded the set of polygons that was digitised by NBN. Then converted to wgs84 but when I try to use the polygons, 8 of them: West Norfolk, Herefordshire, Montgomeryshire, Shropshire, West Ross & Cromarty, Orkney, Outer Hebrides, and Zetland do not work in analysis. Qgis says there is a problem with those ones but says the rest are ok.
> Anyone else had similar issues and/or found ways to fix these?
> -- The Open University is incorporated by Royal Charter (RC 000391), an exempt charity in England & Wales and a charity registered in Scotland (SC 038302). The Open University is authorised and regulated by the Financial Conduct Authority in relation to its secondary activity of credit broking.
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
