[Qgis-user] MemoryLayerSaver plugin - Is there a way to recover data?
Chris Crook ccrook at linz.govt.nz
Mon Jan 27 10:46:12 PST 2020
Hi Julien
This is not a known problem/bug to me (MLS author).  Probably wouldn't be much use filing a bug report unless you have steps to reproduce creating and then failing to read the .mldata file, as there would be no way of testing.  Does it report any particular error when it tries to load the file?
Do you know of anything that might have changed between when you saved the project and when you are trying to reload it.  What version of QGIS was the project saved with.  I doubt that another program would be able to read the file if the memory layer saver plugin cannot, it would just be doing the same python/Qt stuff that it is already doing.  If the file is corrupt then it might be possible to read the data to the point at which it fails.
At the moment it is designed to read all or nothing.  It could be modified fairly easily to read the data up to the point at which it fails (either on a layer by layer or feature by feature basis).
Cheers
Chris
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Julien K.
Sent: Monday, 27 January 2020 9:00 p.m.
To: QGIS Users
Subject: [Qgis-user] MemoryLayerSaver plugin - Is there a way to recover data?
Dear QGis users,
I have a *mldata file generated by MemoryLayerSaver plugin that won't be read when opening the associated QGis project.I tried with 3.4.15-LTR, 3.10.2 rel-dev and dev with no luck, in the QGis project the layers' structure is shown but the tables are empty.
The plugin's source code indicates *mldata files are QStreamData, I don't want to dive into Python/Qt programing at the moment, so is there a simple way to recover the data?
Besides is this a bug or a known problem (i.e. "you've been warned, you should save your memory layers as soon as possible")? Should I file a bug report?
Regards,
Julien
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200127/4145b443/attachment.html>
