[Qgis-user] QGIS Authentication to an ArcGIS Enterprise Portal
Nyall Dawson
nyall.dawson at gmail.com
Wed Jun 3 22:58:23 PDT 2020
On Tue, 2 Jun 2020 at 02:45, Warren Medernach <wmedernach at gmail.com> wrote:
> Hi Myall, just checking in on this to see if you were able to put some details together about the OAuth2 connection to Portal from QGIS. Even a screen cap of working settings would be helpful.
Sorry for the delay -- here you go, a step-by-step write up:
https://north-road.com/2020/06/04/securely-accessing-enterprise-arcgis-portal-sites-through-qgis/
Nyall
> Thanks!
> Warren
> On Tue., May 26, 2020, 6:06 p.m. Warren Medernach, <wmedernach at gmail.com> wrote:
>> That would be fantastic, thank you!
>> Please keep me posted.
>> Warren
>> On Tue, May 26, 2020 at 4:54 PM Nyall Dawson <nyall.dawson at gmail.com> wrote:
>>> On Wed, 27 May 2020 at 09:35, Warren Medernach <wmedernach at gmail.com> wrote:
>>> > Thanks so much for the response Nyall, at least now we know something should be possible.
>>> > Is there anyway you could share a screen cap, or provide some guidance for the required settings in the OAuth2 dialog in QGIS.
>>> Let me see if I can find time to write this up as a blog post later
>>> today... there's a bit involved in the setup which I'd like to step
>>> through
>>> Nyall
>>> > Thanks again,
>>> > Warren
>>> > On Tue, May 26, 2020 at 4:42 PM Nyall Dawson <nyall.dawson at gmail.com> wrote:
>>> >> On Tue, 26 May 2020 at 03:59, Warren Medernach <wmedernach at gmail.com> wrote:
>>> >> > QGIS version: 3.12.2-București
>>> >> > ESRI Portal version: 10.7.1
>>> >> > We have recently been testing out the access to our ESRI Enterprise Portal from QGIS using the ArcGisMapServer and ArcGisFeatureServer connectors. Our Portal is configured via SAML for Enterprise Logins using our corporate domain credentials as well as Built-In ArcGIS Portal users.
>>> >> > We have tried the following Authentication methods: Basic Authentication using a built-in Portal user and Token based Authentication.
>>> >> > It doesn't seem to matter which auth method we use, QGIS will only see content that is shared with Everyone in the Portal.
>>> >> > Is it possible to connect to an ESRI Portal and have QGIS only show content the user has access to based on their settings in the ESRI Portal? ie. the Groups and Content they have access to.
>>> >> I've had great experience using the o2 authentication setup and ESRI
>>> >> Portal. In recent QGIS releases this is seamless and should exactly
>>> >> match your needs.
>>> >> Nyall
