[Qgis-user] QGIS Authentication to an ArcGIS Enterprise Portal
Nyall Dawson
nyall.dawson at gmail.com
Thu Jun 4 22:48:19 PDT 2020
On Fri, 5 Jun 2020 at 01:53, Warren Medernach <wmedernach at gmail.com> wrote:
> Thank you so much Nyall, and no apologies necessary!
> We are successfully able to login now, so this is a huge step forward.
> The one adjustment in the instructions that might help would be to change the connection details to the REST endpoint. The majority of installs I've come across, and most of the ESRI docs, reference the endpoint as 'arcgis' not 'server':
> https://mydoamin.com/arcgis/rest/services
> vs.
> https://mydomain.com/server/rest/services
Thanks for the feedback -- I've made that change now!
Nyall
