[Qgis-user] split polygon with lines seems not working correctly
Luigi Raffaele Sapone studioingsapone at live.com
Wed Jun 10 10:55:05 PDT 2020
Dear David
Thanks for your prompt reply.
I understood the need for intersection between lines and polygons. But the polygonal layer I work on can have thousands of polygons, and manually lengthening the lines is not ....feasible. A procedure would be needed to automate this operation. Or, an alternative method (transforming the line divide layer into polygons, or other procedures that can be implemented automatically, I don't know).
Regards
-----Messaggio originale-----
Da: Qgis-user <qgis-user-bounces at lists.osgeo.org> Per conto di qgis-user-request at lists.osgeo.org
Inviato: mercoledì 10 giugno 2020 19:02
A: qgis-user at lists.osgeo.org
Oggetto: Qgis-user Digest, Vol 172, Issue 15
Send Qgis-user mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
	https://nam11.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user&data=02%7C01%7C%7C14f8af4905d04a9baabd08d80d6020a4%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637274053798286325&sdata=1HM%2FeL6ElSKMxahzf7Vtn40F0WneB0yDOVaSltg9uUE%3D&reserved=0
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
	qgis-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific than "Re: Contents of Qgis-user digest..."
Today's Topics:
   1. Re: Cut shapefiles (Richard McDonnell)
   2. Re: QGIS mailing lists in NABBLE (Andrea Giudiceandrea)
   3. Re: Cut shapefiles (r.chogan at hotmail.com)
   4. Re: QGIS mailing lists in NABBLE (Andrea Giudiceandrea)
   5. split polygon with lines seems not working correctly
      (Luigi Raffaele Sapone)
   6. Re: split polygon with lines seems not working correctly
      (David Greenewalt)
Message: 1
Date: Wed, 10 Jun 2020 08:35:03 +0000
From: Richard McDonnell <richard.mcdonnell at opw.ie>
To: Riccardo D'Alvito <r.chogan at hotmail.com>,
	"qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] Cut shapefiles
Message-ID: <3acfb00ccdf0493db4b8e0ea7f197b48 at opw.ie>
Content-Type: text/plain; charset="utf-8"
Hi Riccardo,
You could try the Split with Lines tool available in the Processing Toolbox, under Vector Overlay. Just use "Split" in the search bar to narrow down the list.
Hope this helps,
Richard
Richard McDonnell MSc GIS, FME Certified Professional FRM Data Management
Oifig na nOibreacha Poibl?
Office of Public Works
Sr?id Jonathan Swift, Baile ?tha Troim, Co na M?, C15 NX36 Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 1 647 6543
https://nam11.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.opw.ie%2F&data=02%7C01%7C%7C14f8af4905d04a9baabd08d80d6020a4%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637274053798296317&sdata=HPMG%2FmndeUl0ZH58kgNn1Sn1NVs14Tvztr1%2FyTi8aow%3D&reserved=0
To send me files larger than 30MB, please use the link below https://nam11.safelinks.protection.outlook.com/?url=https%3A%2F%2Ffiletransfer.opw.ie%2Ffiledrop%2Frichard.mcdonnell%40opw.ie&data=02%7C01%7C%7C14f8af4905d04a9baabd08d80d6020a4%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637274053798296317&sdata=fVXcYitWgdbQF3LchUTNNNW1Q7I9q9UZQ4pgkYb8luQ%3D&reserved=0
Email Disclaimer: https://nam11.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.opw.ie%2Fen%2Fdisclaimer%2F&data=02%7C01%7C%7C14f8af4905d04a9baabd08d80d6020a4%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637274053798296317&sdata=nUHXN3chTovGpOMBSai7IhywUTLWTCaseq4V0%2FWt%2FGA%3D&reserved=0
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Riccardo D'Alvito
Sent: 09 June 2020 17:43
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Cut shapefiles
Good evening.
I would like to cut a shapefile of areas with respect to a shapefile of lines in order to have a resulting shapefile of areas formed by the contours of the various lines.
In other words, "Polygon" has a larger extension than "Lines" . I would like to create another area shape made up of various polygons divided according to the outline of the "Lines" shapefile.
I hope I was clear.
Thanks
URL: <https://nam11.safelinks.protection.outlook.com/?url=http%3A%2F%2Flists.osgeo.org%2Fpipermail%2Fqgis-user%2Fattachments%2F20200610%2F523dd577%2Fattachment-0001.html&data=02%7C01%7C%7C14f8af4905d04a9baabd08d80d6020a4%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637274053798296317&sdata=%2B7aHt%2Fo77IcbqL%2FXAD%2BpgwcyfWU5lbEvl%2BV3ixEKA%2F4%3D&reserved=0>
Message: 2
Date: Wed, 10 Jun 2020 02:51:27 -0700 (MST)
From: Andrea Giudiceandrea <andreaerdna at libero.it>
Subject: Re: [Qgis-user] QGIS mailing lists in NABBLE
Message-ID: <1591782687069-0.post at n6.nabble.com>
Content-Type: text/plain; charset=us-ascii
Richard Duivenvoorde wrote
> ?aybe contact Nabble, as personally I am not aware that we arranged
> something with them?
> We use osgeo-mailing lists, I'm not aware of any changes recently.
> Are other mailing lists affected?
Hi Stefano and Richard,
all the OSGeo ML were affected.
I sent an e-mail message to the OSGeo Nabble Admin two days ago, and after a few attempts, now it's allowed to post new message or replay to messages via Nabble again.
Regards
Sent from: https://nam11.safelinks.protection.outlook.com/?url=http%3A%2F%2Fosgeo-org.1560.x6.nabble.com%2FQGIS-User-f4125267.html&data=02%7C01%7C%7C14f8af4905d04a9baabd08d80d6020a4%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637274053798296317&sdata=RUvniJw%2BrnEcBfZr%2F%2FSjdb3xSXhrrIt4F1cahY2uCh0%3D&reserved=0
Message: 3
Date: Wed, 10 Jun 2020 12:15:25 +0200
To: Richard McDonnell <richard.mcdonnell at opw.ie>
Cc: qgis-user at lists.osgeo.org
Message-ID:
	<DB6P18901MB02151C54DF33BA300040D69F9F830 at DB6P18901MB0215.EURP189.PROD.OUTLOOK.COM>
URL: <https://nam11.safelinks.protection.outlook.com/?url=http%3A%2F%2Flists.osgeo.org%2Fpipermail%2Fqgis-user%2Fattachments%2F20200610%2F918813cc%2Fattachment-0001.html&data=02%7C01%7C%7C14f8af4905d04a9baabd08d80d6020a4%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637274053798296317&sdata=7eTm396zukzDyE89GW%2BVHn%2BfUoN5Hra56am51cEdndA%3D&reserved=0>
Message: 4
Date: Wed, 10 Jun 2020 04:01:52 -0700 (MST)
Message-ID: <1591786912755-0.post at n6.nabble.com>
> again.
Actually... with the exception, form QGIS MLs, of QGIS Italian User
(qgis-it-user) and QGIS - Community Team (qgis-community-team).
For the former, Jorge Sanz. the OSGeo Nabble Admin, said that the Italian group apparently had more restrictive settings so he decided to keep them untouched, for the latter, I don't know why but maybe due to the same reason.
Regards.
Andrea
Message: 5
Date: Wed, 10 Jun 2020 15:31:09 +0000
From: Luigi Raffaele Sapone <studioingsapone at live.com>
To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] split polygon with lines seems not working
	correctly
Message-ID:
	<VI1PR0202MB3455FE9085C04258F9B093C1D5830 at VI1PR0202MB3455.eurprd02.prod.outlook.com>
Hello
I'm using QGIS 3.12
I have a poly shapefile named building.shp in the zip file, and a line shapefile, named line.shp.
I'm using the geoprocessing function 'split polygon by line' using  poly.shp as input, and line.shp as divide layer.
I obtain the 'split_by_line.shp'. But, in this splitted file, the polygon was not divided considering all the lines present, but only some of them, as visible in 'split_by_line.shp'.
Is there something wrong?
Regards
URL: <https://nam11.safelinks.protection.outlook.com/?url=http%3A%2F%2Flists.osgeo.org%2Fpipermail%2Fqgis-user%2Fattachments%2F20200610%2Fcf19775c%2Fattachment-0001.html&data=02%7C01%7C%7C14f8af4905d04a9baabd08d80d6020a4%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637274053798296317&sdata=PxjOXbo7q1SgHazLBleI%2FDYfI5mUYUmAdFMFEgoQNco%3D&reserved=0>
Type: application/x-zip-compressed
Desc: temp.zip
URL: <https://nam11.safelinks.protection.outlook.com/?url=http%3A%2F%2Flists.osgeo.org%2Fpipermail%2Fqgis-user%2Fattachments%2F20200610%2Fcf19775c%2Fattachment-0001.bin&data=02%7C01%7C%7C14f8af4905d04a9baabd08d80d6020a4%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637274053798296317&sdata=nkGDS4GHMBGGjmdPXE2UpuPdZMmxUeiJ2CxOrR1c1%2Fo%3D&reserved=0>
Message: 6
Date: Wed, 10 Jun 2020 12:56:46 -0400
Subject: Re: [Qgis-user] split polygon with lines seems not working
	correctly
Message-ID: <95389106-835d-3eaf-cf5f-ca255c8f0c33 at sover.net>
Content-Type: text/plain; charset="windows-1252"; Format="flowed"
Luigi,
The lines must fully transect the polygon in order to split.  The dotted lines in the image are examples of such lines.
Hope this helps,
David
On 6/10/2020 11:31 AM, Luigi Raffaele Sapone wrote:
> Hello
> I’m using QGIS 3.12
> I’m using the geoprocessing function ‘split polygon by line’ using
> I obtain the ‘split_by_line.shp’. But, in this splitted file, the
> some of them, as visible in ‘split_by_line.shp’.
> Regards
> List info:
> C0%7C637274053798296317&sdata=lL3y%2FmXItAbrpfU%2FKDID9zRc0hBZppgs
> QTcAAco8cW0%3D&reserved=0
> Unsubscribe:
URL: <https://nam11.safelinks.protection.outlook.com/?url=http%3A%2F%2Flists.osgeo.org%2Fpipermail%2Fqgis-user%2Fattachments%2F20200610%2Fd3c185cf%2Fattachment.html&data=02%7C01%7C%7C14f8af4905d04a9baabd08d80d6020a4%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637274053798296317&sdata=c8CdV3Hy2n0wOy8Z6xX7vFz0TOz7NTAbUUPNC4jBVsU%3D&reserved=0>
Name: split lines.jpeg
Type: image/jpeg
Desc: not available
URL: <https://nam11.safelinks.protection.outlook.com/?url=http%3A%2F%2Flists.osgeo.org%2Fpipermail%2Fqgis-user%2Fattachments%2F20200610%2Fd3c185cf%2Fattachment.jpeg&data=02%7C01%7C%7C14f8af4905d04a9baabd08d80d6020a4%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637274053798296317&sdata=Mjv65ikIK9JzrMuyak6J9WjNejlvZvxjhT6MyFJDVbE%3D&reserved=0>
Subject: Digest Footer
List info: https://nam11.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user&data=02%7C01%7C%7C14f8af4905d04a9baabd08d80d6020a4%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637274053798296317&sdata=lL3y%2FmXItAbrpfU%2FKDID9zRc0hBZppgsQTcAAco8cW0%3D&reserved=0
Unsubscribe: https://nam11.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user&data=02%7C01%7C%7C14f8af4905d04a9baabd08d80d6020a4%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637274053798306312&sdata=b4ggGLML5HOtsn8iOhz50%2FJ%2FI2JfmCWx0%2Fs%2Be26foyA%3D&reserved=0
End of Qgis-user Digest, Vol 172, Issue 15
