[Qgis-user] split polygon with lines seems not working correctly
David Greenewalt
dlg at sover.net
Wed Jun 10 12:06:02 PDT 2020
Luigi,
I see the problem now, I would suggest:
1. Polygons to Lines (on the Buildings layer)
2. Merge vector Layers (lines-from-buildings, and line layer)
3. Polygonize (merged layer)
4. Join Attributes from Location (New polygons, building layer)
(Geometric predicate = within)
David
On 6/10/2020 11:31 AM, Luigi Raffaele Sapone wrote:
> Hello
> I’m using QGIS 3.12
> I have a poly shapefile named building.shp in the zip file, and a line
> shapefile, named line.shp.
> I’m using the geoprocessing function ‘split polygon by line’ using
> poly.shp as input, and line.shp as divide layer.
> I obtain the ‘split_by_line.shp’. But, in this splitted file, the
> polygon was not divided considering all the lines present, but only
> some of them, as visible in ‘split_by_line.shp’.
> Is there something wrong?
> Regards
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200610/dd25f9d6/attachment.html>
