[Qgis-user] make a shapefile read-only
Aldo Piombino aldo.piombino at tiscali.it
Fri Jun 12 07:05:44 PDT 2020
thank you.
the solution was under my eyes..
it's clear that all the users need to do so. I will send a "definitive"
version of the Shape to all, recommending the operation
Aldo
Il 12/06/20 15:57, Andreas Neumann ha scritto:
> Hi Aldo,
> Yes. In "Project" - "Properties" there is a "Read only" column where
> you can set individual layers as "read only".
> But this has only an effect in the respective project. Other projects
> could still edit the file. And of course the user can go there and
> disable the checkbox. Thus it is not a real "protection" - only
> against "accidental" edits, but not against "deliberate" edits.
> Greetings,
> Andreas
> On 2020-06-12 15:15, Aldo Piombino wrote:
>> Hi all
>> I have a problem: I use in a projet a shapefile that I must consider
>> as a read-only file.
>> But the risk of a mistake, making the file get accidentally changed,
>> already exists, and for many reasons I don't want to do so
>> Is it possible in QGIS to make a shapefile impossible to modify?
>> thanks
>> Aldo
             Dr.Aldo Piombino
Scienzeedintorni: www.aldopiombino.blogspot.it
            Skype: aldo.piombino
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200612/0d09d4d3/attachment.html>
