[Qgis-user] Multiple Layers
Stewart Holt
stewartbholt at gmail.com
Mon Jun 15 09:32:16 PDT 2020
Try some searches related to setting ulimit default, or at login. There
should be a script somewhere where you could set this and it would apply to
QGIS and anything else you run.
On Mon, Jun 15, 2020 at 11:36 AM Mike Flannigan <mikeflan at att.net> wrote:
> Thanks for the response. I think when I double
> the ulimit to 2048 I am not really doing anything
> positive for QGIS. I think it is just increasing
> the ulimit for the terminal window, since each
> terminal window appears to have its own ulimit.
> Doubling the ulimit to 2048 also doesn't appear to
> fix the problem.
> I notice that when I turn on layers the CPU goes to
> 100% and stays there for a minute or more (in htop).
> If I let it settle back down to near 0%, then QGIS
> keeps working. If I keep clicking layers QGIS
> freezes.
> I think my system is fairly beefy, but maybe not:
> CPU: Topology: Quad Core model: Intel Xeon E5-1630 v4 bits: 64
> type: MT MCP arch: Broadwell
> rev: 1 L2 cache: 10.0 MiB
> flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
> bogomips: 59062
> Speed: 2854 MHz min/max: 1200/4000 MHz Core speeds (MHz): 1:
> 1973 2: 1198 3: 1198
> 4: 1201 5: 1642 6: 1197 7: 1197 8: 1197
> Graphics: Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB]
> Anyway, this problem is not hindering my work too much.
> I will let you know if I find a good solution to it.
> Mike
> On 6/15/20 9:36 AM, qgis-user-request at lists.osgeo.org wrote:
> > Date: Mon, 15 Jun 2020 15:31:29 +0200
> > From: Régis Haubourg<regis.haubourg at gmail.com>
> > To: Mike Flannigan<mikeflan at att.net>
> > Cc: Qgis Users List - International<qgis-user at lists.osgeo.org>
> > Subject: Re: [Qgis-user] Multiple Layers
> > Message-ID:
> > <CABgOYCd5LApg3BvqrD=
> t1EtwmoJ1FZJ_6G2AmqktgsQp1+-e2A at mail.gmail.com>
> > Content-Type: text/plain; charset="utf-8"
> > Hi Mike,
> > you probably encounter the "max file opened by your system" issue. And
> shp
> > count for 3.
> > Best advice is to switch to DB connexions, which do not open any file and
> > removes this limit
> > Best regards
> > Régis
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200615/bb6db30f/attachment.html>
