[Qgis-user] shapefiles
shrawan tripathi shrawantripathi1983 at gmail.com
Tue Jun 16 00:52:13 PDT 2020
Dear jim, please keep shapefile layer above orthoimage in layer panel
On Tue, 16 Jun, 2020, 1:20 PM forestermcgannon, <forestermcgannon at gmail.com>
wrote:
> when I "uncheck" the ortho layer, the property boundary (the shapefile)
> appears. When I display the ortho imagery again, no boundary. It is like
> the shapefile is "under" the ortho image, when I of course want it to show
> "on" the ortho image. most seems like a vector display issue to me.
> What do you think?
> Thanks
> Jim
> Jim McGannon
> Forestry Landscape Consultant, LLC
> Coloradotreearborist.com
> 303-526-1118
> -------- Original message --------
> From: Raymond Nijssen <r.nijssen at terglobo.nl>
> Date: 6/15/20 11:35 PM (GMT-07:00)
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] shapefiles
> Hi Jim,
> That sounds a lot like a projection issue.
> Are your layers completely misaligned, like not overlapping at all? Or
> are they overlapping but with just a few (hundred) meters shift?
> An easy trick is adding the world layer and see which of your layers
> appears at the expected spot. You can do this by typing "world" in the
> coordinate bar beneath the map.
> Good luck!
> Raymond
> On 16-06-2020 05:24, forestermcgannon wrote:
> > Why is my shapefile that I imported into project, not showing up with my
> > orthoimage. The shapefile is a property line boundary.
> > Thanks
> > Jim
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200616/d084d09c/attachment.html>
