[Qgis-user] intersection batch process
nwastra nwastra nwastra at gmail.com
Tue Jun 23 04:19:35 PDT 2020
Here are test files
https://drive.google.com/drive/folders/1wXTOlTrDWSZOev6UvHML7lkgd0lF2Wyx?usp=sharing <https://drive.google.com/drive/folders/1wXTOlTrDWSZOev6UvHML7lkgd0lF2Wyx?usp=sharing>
I am trying to reduce the streams extent to the Curt polygon using batch process (one line should be fine to test)
It works as a single process but does not output anything useful when using the batch process page.
> Begin forwarded message:
> From: nwastra nwastra <nwastra at gmail.com>
> Subject: intersection batch process
> Date: 23 June 2020 at 8:14:02 pm AEST
> To: qgis-user at lists.osgeo.org
> I am using Vector>GeoProcessing Tools>Intersection and want to 'run as batch process’
> I enter the input and overlay layers and leave the input, overlay fields and intersection as autofill but get an error "Wrong or missing output value: Intersection (row 1)” for all rows if I don’t enter an output filename.
> I see where to enter the output dir/filename under the ‘Intersection’ column and choose a new shapefile name and am then asked for autofill settings.
> I choose 'Fill with parameter values' and 'input fields to keep left empty to keep all fields’.
> The input layer has many fields
> And I get no output and no error
> Running as a single process works fine.
> What am I missing here?
> I haven’t uploaded files due to size
> QGIS version
> 3.14.0-Pi
> OS Version
> macOS 10.15
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200623/2f2449db/attachment.html>
