[Qgis-user] Http access to json return
Ben Hur Pintor
bnhr.dev at gmail.com
Wed Jun 24 01:23:25 PDT 2020
Hi!
If it's a vector layer (e.g. geojson response) that you'll load via API,
you can try using the Data Source Manager -> Vector Tab and use *Protocol:
HTTP(S), cloud, etc.*. You can select the proper *Type* and input the
*URI* similar
to the image below. This will load the file/response as a QGIS layer.
I haven't tried it yet for CSV / non-spatial data though.
All the best,
Ben Hur
On Wed, Jun 24, 2020 at 2:23 PM Andreas Neumann <a.neumann at carto.net> wrote:
> Hi Steve,
> Not that I know of, but:
> - you could have an onload Python script that runs when the form opens
> - you could have a web-widget with an onload javascript that does some
> network requests
> Such rather "developer centric" questions are more likely to get responses
> on the qgis-developer mailing lists, btw.
> Greetings,
> Andreas
> On 2020-06-24 07:22, Steve Sgalowski wrote:
> Is there widget on qgis that does http out with api and returns data in
> json or csv format?.
> Stephen.
> Qgis-user mailing list
*Ben Hur S. Pintor*
bnhr.xyz
hi at bnhr.xyz
open spatial & data solutions
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200624/228299de/attachment.html>
