[Qgis-user] Http access to json return
Alessandro Pasotti
apasotti at gmail.com
Wed Jun 24 04:55:12 PDT 2020
You can have a look to
https://qgis.org/pyqgis/3.2/core/File/QgsFileDownloader.html , store the
contents to a temporary file and then load it.
... or also
https://qgis.org/pyqgis/3.2/core/Network/QgsNetworkContentFetcher.html?highlight=fetcher#module-QgsNetworkContentFetcher
Both classes handle QGIS authentication configurations and proxies, OAuth2
is also supported by both.
On Wed, Jun 24, 2020 at 1:37 PM Karl Magnus Jönsson <
Karl-Magnus.Jonsson at kristianstad.se> wrote:
> Hi!
> I’m also interested this functionality. Need to use OAuht2 authentication
> but that seems not to be available. Guess there is just an solution
> programmatically then.
> *Karl-Magnus*
> *Från:* Qgis-user <qgis-user-bounces at lists.osgeo.org> *För *Ben Hur Pintor
> *Skickat:* den 24 juni 2020 10:23
> *Till:* Steve Sgalowski <steve.sgalowski at gmail.com>
> *Kopia:* QGIS User <Qgis-user at lists.osgeo.org>
> *Ämne:* Re: [Qgis-user] Http access to json return
> Hi!
> If it's a vector layer (e.g. geojson response) that you'll load via API,
> you can try using the Data Source Manager -> Vector Tab and use *Protocol:
> HTTP(S), cloud, etc.*. You can select the proper *Type* and input the
> *URI* similar to the image below. This will load the file/response as a
> QGIS layer.
> I haven't tried it yet for CSV / non-spatial data though.
> All the best,
> Ben Hur
> On Wed, Jun 24, 2020 at 2:23 PM Andreas Neumann <a.neumann at carto.net>
> wrote:
> Hi Steve,
> Not that I know of, but:
> - you could have an onload Python script that runs when the form opens
> - you could have a web-widget with an onload javascript that does some
> network requests
> Such rather "developer centric" questions are more likely to get responses
> on the qgis-developer mailing lists, btw.
> Greetings,
> Andreas
> On 2020-06-24 07:22, Steve Sgalowski wrote:
> Is there widget on qgis that does http out with api and returns data in
> json or csv format?.
> Stephen.
> Qgis-user mailing list
> *Ben Hur S. Pintor*
> bnhr.xyz
> hi at bnhr.xyz
> open spatial & data solutions
Alessandro Pasotti
QCooperative: www.qcooperative.net
ItOpen: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200624/80881273/attachment.html>
