[Qgis-user] Using 1:n table relationships in rule-based symbology
Jeanneret Cédric Cedric.Jeanneret at ville-fr.ch
Tue Mar 3 23:44:15 PST 2020
Hello,
I would like to use the value of a field/attribute in a parent table as a filter in an expression used to display features in the child table.
Specifically, I have a 1:n relationship (composite) saved in my project:
Sectors (parent table with polygon geometry, a key "FID" and a field/attribute "TYPE")
Trees (child table with point geometry, and a secondary key "SECTORS_ID")
I would like to use this relationship in the rule-based symbology renderer so that, for example:
Trees whose parent Sectors have "TYPE" = 'Project' are displayed as a blue circle
Trees whose parent Sectors have "TYPE" = 'Parking' are displayed as a red circle
My questions:
Using the relate, how do I build my expression in the rule-based renderer so that I can differentiate between Trees related to a Sector of a specific type?
Should I look for a way to use « @parent » in the child table, along with the get_feature() and/or attribute() function ? I understand the @parent parameter is only used for the aggregate() function.
The expression should make use of the relate, using the value of the parent attribute "TYPE" ; also, the condition is not always spatial thus refFunction plugin is not being used. The point is also not to use a view.
I'd rather avoid the following, but as an alternative: how would I create a virtual field "SECTOR_TYPE" in my child table that would be filled with the value of the "TYPE" field located in the corresponding parent feature?
I am using QGIS 3.10.1
Thanks in advance for your help.
CJ
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200304/0bcb948c/attachment.html>
