[Qgis-user] QGIS uninstalled after GDAL PPA install
Lorenzo-Outlook morettilorenzo at outlook.com
Thu Mar 5 16:01:04 PST 2020
Thank you very much!
I completely removed the previous installation of QGIS 3.12 and installed the LTR release QGIS 3.10.3 using 'qgis.org/ubuntu-ltr'. I also installed the server version and now everything works. Great.
Looking at the libraries used for QGIS I see that there is still GDAL 2.2.3 and PROJ4 4.9.3. Is there any hope to see these libraries updated to version 3.x for GDAL and 6.x for PROJ4 in Ubuntu 18.04?
Thanks again
Lorenzo
> Il giorno 5 mar 2020, alle ore 14:50, Andre Joost <andre+joost at nurfuerspam.de> ha scritto:
> Am 05.03.20 um 00:06 schrieb Lorenzo-Outlook:
>> Hi all I also was able to install the new version 3.12 in Ubuntu
>> 18.04 following the instructions by eliminating the ubuntugis repo.
>> But QGIS is not complete: the problem is strange because QGIS opens
>> and inside it is missing many CRS projections (for example the
>> geographical WGS84, EPSG:4326 or 3857 and others). It seems that the
>> PROJ4 library version 4.9.3 with which QGIS is compiled does not
>> contain some CRS. Everything else works but without these projections
>> QGIS is not much need. Of course the server version also has this
>> problem and is therefore unusable. I went back to the ubuntugis repo
>> and reinstalled QGIS 3.10.2 which works fine. Did someone have the
>> same problem or did it just happen to me? Bye Lorenzo
> This might be a follow-up of QGIS 3.12 expecting PROJ 6.3.1 which is not yet available for Ubuntu (with or without ubuntugis).
> You might switch to the QGIS ubuntu-ltr repo, which contains QGIS 3.10.3 at the moment.
> HTH,
> Andre Joost
> Qgis-user mailing list
