[Qgis-user] sqlcli installation on 32bit and resulting pyodbc error
Paul Wittle paul.wittle at dorsetcouncil.gov.uk
Mon Mar 9 02:39:34 PDT 2020
I’m trying to install QGIS 3.10 32bit but I’m getting an error when it tries to install the Microsoft SQL Server 2012 Native Client. The error reads “Installation of this product failed because it is not supported on this operating system. For information on supported configurations, see the product documentation.”
It worked fine on my 64bit installation and I should note that I’m attempting to run both a 32bit and 64bit version side by side.
When I then load the application one of my plugins (the one requiring 32bit) gives the error:
ModuleNotFoundError: No module named 'pyodbc'
I assume this is because the native client failed to install but has anyone else had this issue and is there a flag I can set in the advanced installer to get the native client to install correctly?
Thank you to Bo Victor Thomsen and Jürgen E. Fischer for answering my earlier question because that got me a working version of 3.10.3 64bit which is great 😊
Many thanks,
Paul
This e-mail and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. It may contain unclassified but sensitive or protectively marked material and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All traffic may be subject to recording and/or monitoring in accordance with relevant legislation. Any views expressed in this message are those of the individual sender, except where the sender specifies and with authority, states them to be the views of Dorset Council. Dorset Council does not accept service of documents by fax or other electronic means. Virus checking: Whilst all reasonable steps have been taken to ensure that this electronic communication and its attachments whether encoded, encrypted or otherwise supplied are free from computer viruses, Dorset Council accepts no liability in respect of any loss, cost, damage or expense suffered as a result of accessing this message or any of its attachments. For information on how Dorset Council processes your information, please see www.dorsetcouncil.gov.uk/416433
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200309/8d79588b/attachment.html>
