[Qgis-user] Query for "Vector blender" Plugin
shrawan tripathi shrawantripathi1983 at gmail.com
Tue Mar 10 14:21:40 PDT 2020
Hi Warner,
 Actually it is not available in QGIS 2.18.12. Now I install QGIS 3.10 and
found in this version. Thanks.
On Tue, Mar 10, 2020 at 2:17 PM Werner Macho <werner.macho at gmail.com> wrote:
> Hi!
> I am not sure what you mean by "suggest me".
> From what you can see here
> https://plugins.qgis.org/plugins/VectorBender/
> The plugin should be available in QGIS 2.18 too (as an older version of
> course .. 0.1.1 ) from version 0.2 onwards it is only available for QGIS
> 3.x.
> I might also be wrong and the plugin is not available for QGIS 2.18 (as I
> am not using QGIS 2.x anymore I cannot confirm - I can only tell you what I
> see on the plugins page.
> regards
> Werner
> On Tue, Mar 10, 2020 at 10:13 PM shrawan tripathi <
> shrawantripathi1983 at gmail.com> wrote:
>> Hi Warner, Thanks for promt response.
>> Basically I have to georeference the vector file, it may be linear or
>> rubber sheet transformation like "spatial adjustment" in Arc_GIS Platform.
>> So please suggest me.
>> On Tue, Mar 10, 2020 at 2:03 PM Werner Macho <werner.macho at gmail.com>
>> wrote:
>>> Hi!
>>> If you mean, which is very likely, the "Vector bender" plugin - this
>>> plugin is available in the repository.
>>> It seems you have a typo in your search and an "l" too much. The search
>>> function is not resistant for typos.
>>> I hope this is what you are looking for.
>>> regards
>>> Werner
>>> On Tue, Mar 10, 2020 at 9:56 PM shrawan tripathi <
>>>> Hi All, I am unable to see the  "Vector blender" Plugin in Plugin
>>>> Manager of QGIS 2.18.12 or older version. Please let me know if any one use
>>>> it.
>>>> Warm regards
>>>> Shrawan Kumar Tripathi
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Warm regards
Warm regards
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200310/e7e9363a/attachment.html>
