[Qgis-user] CRS Errors
Tyler Veinot tylerkveinot at gmail.com
Wed Mar 11 06:16:24 PDT 2020
Has anyone had this issue?
My measurements when using the ellipsoidal measur are in the millions of
meters for things that are only a few hundred or less meters long. It isn't
a unit issue because I tried dividing for cm, mm, dm and the
measurements don't add up. If I go to cartesian the measurements look fine.
Before this was happening my QGIS was also assigning epsg 2292 to my
shapfiles having an epsg of 2954. I check the file geodatabase they were
exported from and the proj files and they all reference EPSG 2954 and not
EPSG 2292. Also All new projects are defaulted to 2954 so no
transformations should be necessary.
Since updating to QGIS3 I noticed this transformation section in the
settings under CRS, is there something here I inadvertently changed?
I do have my own GSB files for coordinate transformations from survey grids
but I have not figured out how to employ them yet in QGIS3 so I don't think
they would be an issue.
Anyone else have a similar thing start to happen?
Thanks;
Tyler
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200311/cdcef40c/attachment.html>
