[Qgis-user] Atlas Generation
Håvard Tveite havard.tveite at nmbu.no
Thu Mar 19 00:23:27 PDT 2020
Sorry about that - I have been working with reports lately...
I tested for Atlas now (QGIS 3.12), and the corresponding
Atlas procedure also produced the atlas as a 20cm by 20 cm
PDF document:
0) I assume that the map for the "report" is already prepared.
1) Create a new print layout (*Project-> New Print Layout*).
2) Activate *Atlas setting* (Atlas-> Atlas Settings) and select
    your point layer as *Coverage Layer* under *Configuration*.
4) Check *Hidden coverage layer*, and if you want sorting,
    check *Sort by* and select a field (from the point layer).
5) If you right-click in the white "sheet" that shows up on the
    gray canvas, you can set the page size and orientation.
    Specify "Custom" with a *Width* of 200 mm and a *Height* of
    200 mm in *Item Properties* to the right.
6) Add your map (Add Item-> Add Map, by dragging out the rectangle
    for it on the canvas).
7) In the *Item Properties* of the map, select your preferred
    map *Scale*.
8) Scroll down and check *Controlled by Atlas*. *Fixed scale*
    will be the selected (and, for point layers, only possible)
    option.
9) Export your map to PDF (*Atlas-> Export Atlas as PDF...*) and
    check the results (I get 20cm x 20 cm pages)
Håvard
On 19.03.2020 02:24, stellar0645 wrote:
> Ok, thanks very much.
> I'll give it a try, although I'm trying to create an Atlas, not a Report.
> Perhaps they are similar.  I'm reluctant to start down a fresh rabbit hole.
> Thanks again . . . . .
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
