[Qgis-user] OpenLayersPlugin
Paolo Cavallini cavallini at faunalia.it
Fri Mar 20 11:32:11 PDT 2020
Hi Tim,
please upgrade to the latest LTR version, now 3.10.
Instead of OL plugin, you can use QuickWebServices.
All the best.
Il 20/03/20 19:21, Tim Smith ha scritto:
> Hi All
> I am using QGIS 2.18.17 on Linux Mint 19.3.  What I need to do is
> display a Google or other aerial image such as Bing on my map. So, I am
> trying to install OpenLayers Plugin but keep getting an error saying
> 'The plugin is broken. Python said cannot import name QtWebKit'. I also
> get the following:
>> Couldn't load plugin openlayers_plugin due to an error when calling
>> its classFactory() method
>> ImportError: cannot import name QtWebKit
>> Traceback (most recent call last):
>>   File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 333, in
>> startPlugin
>>     plugins[packageName] = package.classFactory(iface)
>>   File
>> "/home/tim/.qgis2/python/plugins/openlayers_plugin/__init__.py", line
>> 25, in classFactory
>>     from openlayers_plugin import OpenlayersPlugin
>>   File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 607, in
>> _import
>>     mod = _builtin_import(name, globals, locals, fromlist, level)
>>   File
>> "/home/tim/.qgis2/python/plugins/openlayers_plugin/openlayers_plugin.py",
>> line 30, in
>>     from openlayers_overview import OLOverview
>> _import
>>   File
>> "/home/tim/.qgis2/python/plugins/openlayers_plugin/openlayers_overview.py",
>> line 23, in
>>     from openlayers_ovwidget import OpenLayersOverviewWidget
>> _import
>>   File
>> "/home/tim/.qgis2/python/plugins/openlayers_plugin/openlayers_ovwidget.py",
>> line 38, in
>>     from ui_openlayers_ovwidget import Ui_Form
>> _import
>>   File
>> "/home/tim/.qgis2/python/plugins/openlayers_plugin/ui_openlayers_ovwidget.py",
>> line 80, in
>>     from PyQt4 import QtWebKit
>> Python version: 2.7.17 (default, Nov  7 2019, 10:07:09) [GCC 7.4.0]
>> QGIS version: 2.18.17 Las Palmas, exported
>> Python Path:
>>   * /usr/share/qgis/python/plugins/processing
>>   * /home/tim/.qgis2/python
>>   * /home/tim/.qgis2/python/plugins
>>   * /usr/lib/python2.7
>>   * /usr/lib/python2.7/plat-x86_64-linux-gnu
>>   * /usr/lib/python2.7/lib-tk
>>   * /usr/lib/python2.7/lib-old
>>   * /usr/lib/python2.7/lib-dynload
>>   * /usr/local/lib/python2.7/dist-packages
>>   * /usr/lib/python2.7/dist-packages
>>   * /usr/lib/python2.7/dist-packages/gtk-2.0
>>   * /home/tim/.qgis2//python
>>   * /home/tim/.qgis2/python/plugins/go2streetview
> I get a similar error when I try to load other plugins such as
> gotostreetview. Please could anybody advise how I can get the plugin
> working so I can use an aerial image on my map, thank you?
> Kind Regards
> Tim
> *Tim Smith BSc (Hons) MCIEEM*
> /Managing Director and Principal Ecologist/
>  Five Valleys Ecology Logo Small    CIEEM Registered Practice logo
> 2019-2020_250x384
> *Informing - Reducing Risk - Adding Value*
> www.fivevalleysecology.co.uk <http://www.fivevalleysecology.co.uk/>
> T: +44 (0)1453 759306 – Choose Option 1
> M: +44 (0)7732 397984
> 5 St Brendans Road
> Stroud
> Gloucestershire
> GL5 1PB
> CIEEM Member Subject to Code of Professional Conduct
> Registered in England No. 7540564
> VAT No. 133 4074 43
> This email and any files transmitted with it are confidential and
> intended solely for the use of the individual or entity to whom they are
> addressed. If you have received this email in error please notify the
> system manager. This message contains confidential information and is
> intended only for the individual named. If you are not the named
> addressee you should not disseminate, distribute or copy this email.
> Please notify Five Valleys Ecology Ltd immediately by email if you have
> received this email by mistake and delete this email from your system.
> If you are not the intended recipient you are notified that disclosing,
> copying, distributing or taking any action in reliance on the contents
> of this information is strictly prohibited.
> We have checked this email and its attachments for viruses. The
> recipient should also check this email and any attachments for the
> presence of viruses. Five Valleys Ecology Ltd accepts no liability for
> any damage caused by any virus transmitted by this email.
> Description: Please consider the environment before printing this email
> Qgis-user mailing list
Paolo Cavallini - www.faunalia.eu
QGIS.ORG Chair:
http://planet.qgis.org/planet/user/28/tag/qgis%20board/
