[Qgis-user] Cannot open after downloading
Christoph Jung jagodki.cj at gmail.com
Tue Mar 31 02:39:01 PDT 2020
Hi Josh,
This question is not new in this mailing list :)
Two options were given in this list earlier:
1.
When you tried to open QGIS and this dialogue appears, exit it with Ok. Then go immediately to the security settings in the settings app. At the bottom of the window there should be a button that you nevertheless want to open the application. Press this button and confirm the following dialogue. Then QGIS should start. You do not have to repeat this procedure, i.e. Gatekeeper will make an exemption for QGIS.
Or 2.
Right-click on QGIS, the following dialog box will show an additional button that says something like "Open".
Sincerely,
Christoph
> Am 30.03.2020 um 20:26 schrieb Josh Wisniewski <merganseranthro at gmail.com>:
> Attempted to open after download received pop up messages
> “QGIS3.10” can’t be opened because Apple cannot check it for malicious software.
> This software needs to be updated. Contact the developer for more information.
> Please advise
> Josh Wisniewski
> 907-623-7144
> Qgis-user mailing list
