[Qgis-user] Should be easy? Open csv in Graphical Modeller
kirk kirk at nortekresources.com
Tue Mar 31 03:26:51 PDT 2020
Hi Morton. Open your csv file, define your coordinate fields and set your coordinate system. Now you will have a virtual layer from your data.  If you want to run some processing, save the layer as a shapefile or gis format. Once you have saved the layer, you can continue with your analysis.Kirk Schmidt Nortel Resource Solutions Inc.Sent from my Samsung Galaxy smartphone.
-------- Original message --------From: magerlin <MAP at ramboll.dk> Date: 2020-03-31  6:56 AM  (GMT-04:00) To: qgis-user at lists.osgeo.org Subject: Re: [Qgis-user] Should be easy? Open csv in Graphical Modeller Thanks for your response.But I do not think it should be that complicated?I am not into Python.....-----Regards MortenCurrently using Qgis 3.10.0Windows 10, 64bit--Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html_______________________________________________Qgis-user mailing listQgis-user at lists.osgeo.orgList info: https://lists.osgeo.org/mailman/listinfo/qgis-userUnsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200331/0036679f/attachment.html>
