[Qgis-user] Should be easy? Open csv in Graphical Modeller
magerlin MAP at ramboll.dk
Tue Mar 31 03:51:20 PDT 2020
OK - found the reason :-)
They are technically csv files but in the GTFS standard the files are named
as .txt files.
Which QGIS apparently not can handle. Renaming to .csv did the trick
Regards Morten
Currently using Qgis 3.10.0
Windows 10, 64bit
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
