[Qgis-user] Keeping layers of an imported DXF file into QGIS
Andreas Neumann
andreas at qgis.org
Mon Nov 9 07:31:58 PST 2020
See
https://docs.qgis.org/3.16/en/docs/user_manual/managing_data_source/opening_data.html#importing-a-dxf-or-dwg-file
for the QGIS native way to import DXF, which also keeps the original layer
structure.
Andreas
On Mon, 9 Nov 2020 at 16:25, Andreas Neumann <andreas at qgis.org> wrote:
> Hi Luc,
> Can you share such a dxf with me?
> As just written in my other mail (seconds ago), please also try the native
> way of importing the DXF to a Geopackage through menu "Project -->
> Import/Export --> Import Layers from DWG/DXF"
> Andreas
> On Mon, 9 Nov 2020 at 16:03, Luc Le Blanc <speleoluc at gmail.com> wrote:
>> That's our impression too, as QGIS ends up with (3) layers of shapes,
>> lines and text. The problem is that this line layer is a bulk merge of
>> several DXF layers representing different things (line plot, passage
>> widths, walls, etc.) that the user would like to toggle (hide/show) or
>> even exclude from the import. Just knowing the layer of origin is not
>> sufficient. Can QGIS act upon these attributes other than just showing
>> them? (I'm not a QGIS user, just researching for an Auriga user who
>> asked me).
>> Le lun. 9 nov. 2020 Ã 09:43, Charles Dixon-Paver <charles at kartoza.com> a
>> écrit :
>> > I think the DXF is just split by geometry type, but you should be able
>> to access the "layer" information via the attributes.
>> > On Mon, 9 Nov 2020 at 16:24, Luc Le Blanc <speleoluc at gmail.com> wrote:
>> >> Hi,
>> >> My cave survey freeware exports DXF files organized in multiple layers
>> >> for survey stations, station names, line plot, wall lines, etc.
>> >> A user tells me that when he imports this DXF into QGIS, everything
>> >> gets merged into 3 layers containing station markers (small
>> >> triangles). lines (line plot, passage widths, walls, altogether) and
>> >> station names.
>> >> Is it possible for QGIS to neatly import a layered DXF file into
>> >> corresponding layers, respecting the initial organization?
>> >> Luc Le Blanc
>> >> http://www.speleo.qc.ca/Auriga
>> >> _______________________________________________
>> >> Qgis-user mailing list
>> >> Qgis-user at lists.osgeo.org
>> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Luc Le Blanc
> Andreas Neumann
> QGIS.ORG board member (treasurer)
Andreas Neumann
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201109/02ab5e0a/attachment.html>
