[Qgis-user] Dynamic Line
Andreas Neumann
a.neumann at carto.net
Fri Nov 13 02:34:31 PST 2020
Or even easier: use the "Vector Field Marker":
https://docs.qgis.org/3.10/en/docs/user_manual/style_library/symbol_selector.html?#the-vector-field-marker
Am 13.11.20 um 11:33 schrieb Andreas Neumann:
> Hi,
> Yes - you can use Geometry Generators for that. Use the make_point()
> and make_line() expressions for that.
> See
> https://docs.qgis.org/3.10/en/docs/user_manual/style_library/symbol_selector.html?highlight=geometry%20generator#the-geometry-generator
> Greetings,
> Andreas
> Am 13.11.20 um 11:26 schrieb L.W.:
>> Hi,
>> is it possible to draw automatically a line between two points defined
>> by 4 fields (x1,y1 - x2,y2) in an attributetable?
>> but I do not want to add a line-layer based on this table nor want to
>> draw the line by hand.
>> thanks
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
