[Qgis-user] Picture data in Map?
Tony Shepherd (FarmMaps NZ) tony at farmmaps.nz
Wed Nov 18 11:04:58 PST 2020
Hi
There is a plugin called “Import Photos”.
It’ very handy for extracting metadata (exif data) from a folder full of images and creating points etc.  I use it to map photo locations then use a calculated field to show an arrow indicating the direction the photo was taken (if collected in the exif).  From memory it also allows you to click a photo and open a built in viewer to view the image.
Also really useful for mapping and quickly viewing drone imagery.
Cheers
Tony
Tony Shepherd  |  GeoSpatial / Mapping Manager
Ph 027 435 6193  |  E  <mailto:tony at farmmaps.nz> tony at farmmaps.nz
FarmMaps NZ, 3 Kerwood Place, Gore 9740
 <http://tonyshepherd8.wixsite.com/home>  <https://www.wunderground.com/personal-weather-station/dashboard?ID=ISTLGORE2>
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Chavoux Luyt
Sent: Wednesday, 18 November 2020 7:47 pm
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Picture data in Map?
Hi guys,
Is there an easy way to get image data into/linked into a map in qGIS (i.e. a plugin or something)? I have CyberTracker data with pictures taken of footprints etc. as recorded in the veld, but when I export it to a .shp file, the associated picture is no longer in the .dbf (neither is there a link to it). What I really want is to have a map where when I click on a specific point, the associated picture would pop up and show on-screen (together with the text data, like species and behaviour associated with that point).
Would I need to use BLOB's (or BYTEA) in PostGIS for this functionality? Has nobody done something similar before?
Any advice appreciated!
Cheers,
Chavoux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201119/674e8b21/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201119/674e8b21/attachment-0001.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201119/674e8b21/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201119/674e8b21/attachment-0003.png>
