[Qgis-user] Polygon from 4 points
    Richard Duivenvoorde
    rdmailings at duif.net
    Sat Nov 28 04:25:55 PST 2020
As a variation on this...
You can create 'virtual layers' in QGIS, see:
https://docs.qgis.org/3.16/en/docs/user_manual/managing_data_source/create_layers.html?highlight=virtual#creating-virtual-layers
In attached zip file (a csv+a project file),
I created a csv with 4 records with (just) 2 coordinates x1,y1,x2,y2.
Loaded it (as table) in QGIS (named it xyxy
Then created a Virtual Layer using one of the following 'Queries':
# a point:
SELECT make_point(x2, y2, 4326) as geometry, x1 as x1, y1 as y1, x2 as x2, y2 as y2 FROM xyxy
# a polygon, one of these:
select geom_from_wkt( 'POLYGON(('||x1||' '||y1||',  '||x2||' '||y1||',   '||x2||' '||y2||',  '||x1||' '||y2||',  '||x1||' '||y1||'))'  ) as geometry, x1 as x1, y1 as y1, x2 as x2, y2 as y2  from xyxy
select st_geomfromtext( 'POLYGON(('||x1||' '||y1||',  '||x2||' '||y1||',   '||x2||' '||y2||',  '||x1||' '||y2||',  '||x1||' '||y1||'))'  ) as geometry, x1 as x1, y1 as y1, x2 as x2, y2 as y2  from xyxy
(in the dialog I selected
Geometry column 'geometry'
Type 'Polygon'
CRS 'EPSG:4326'
In this way, you can just load the QGIS project, and the virtual layer will do the magic for you to create a polygon layer from your csv.
You can probably even use the project file as an input for QGIS-Server to serve it as WMS to you clients.
(but you can also just share the project file).
Regards,
PS it took me some puzzling to get the query/expression right. At first I used concatting with '+' but you have to use the '||' as in expressions....
PS2 you have to update the queries to reflect your 8 columns....
On 11/26/20 4:02 PM, Totò Fiandaca wrote:
> From Processing:
> search for Geometry by Expression:
> 1. as input layer put your file with the coordinates
> 2. and write this expression:
>   make_polygon (
>   make_line (
>   make_point ("x1", "y1"),
>   make_point ("x2", "y2"),
>   make_point ("x3", "y3"),
>   make_point ("x4", "y4")
> and launch the geoprocess.
> I used QGIS 3.16 Hannover
> Il giorno gio 26 nov 2020 alle ore 15:48 Ryan Peel <ryanpeel at gmail.com <mailto:ryanpeel at gmail.com>> ha scritto:
>     I have a csv/table that has a single row that contains some metadata as well as four SEPARATE columns, x1, y1, x2, y2, x3, y3, x4, y4 of decimal degree coordinates.
>     I want to import all of this data into QGIS and create a polygon from the four points as a vector layer.
>     What is the best way to do this?  I'm not a programmer or scripter really and fairly new to QGIS.
>     Thanks!
>     *Ryan Peel*
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
> *Ing. Salvatore Fiandaca*
> *mobile*.:+39 327.493.8955
> *m*: *pigrecoinfinito at gmail.com <mailto:pigrecoinfinito at gmail.com>*
> *C.F*.: FNDSVT71E29Z103G
> *P.IVA*: 06597870820
> *membro QGIS Italia - http://qgis.it/ <http://qgis.it/>*
> *socio GFOSS.it - *http://gfoss.it/ <http://gfoss.it/>
> *blog:** https://pigrecoinfinito.com/ <https://pigrecoinfinito.com/>
> FB: Co-admin - https://www.facebook.com/qgis.it/ <https://www.facebook.com/qgis.it/>**  <https://www.facebook.com/qgis.it/> *
> *TW:  <http://goog_95411464>**https://twitter.com/totofiandaca <https://twitter.com/totofiandaca>*
> 43°51'0.54"N  10°34'27.62"E - EPSG:4326
> “Se la conoscenza deve essere aperta a tutti,
> perchè mai limitarne l’accesso?”
> R. Stallman
> Questo documento, allegati inclusi, contiene informazioni di proprietà di FIANDACA SALVATORE e deve essere utilizzato esclusivamente dal destinatario in relazione alle finalità per le quali è stato ricevuto. E' vietata qualsiasi forma di riproduzione o divulgazione senza l'esplicito consenso di FIANDACA SALVATORE. Qualora fosse stato ricevuto per errore si prega di informare tempestivamente il mittente e distruggere la copia in proprio possesso.
Type: application/zip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201128/b9b5b989/attachment.zip>
