[Qgis-user] creating one portable QGIS project
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Wed Oct 7 03:21:49 PDT 2020
From what I now read and tried, that solution seems to be far from what
Andre wants.
It seems, you can save it TO a gpkg and not AS a gpkg.
So in case your complete project data is not already stored within a
gpkg, it won't collect and dump it as QConsolidate does. (correct?)
Maybe someone could shed a light about an best-practice-approach, how to
organize and store the data so this tool will give a smooth workflow.
(thinking e.g. of how to deal with big permanent datasets on networks
drives etc. )
Cheers,
Bernd
On 07.10.20 11:56, Andreas Neumann wrote:
> For storing the .qgs file in a geopackage you can simply do "Project"
> --> "Save As" --> "Geopackage".
> I think you could even have multiple .qgs project files in a single
> Geopackage.
> Andreas
> On 2020-10-07 11:50, Richard Duivenvoorde wrote:
>> On 10/7/20 11:45 AM, Andre Ulrich wrote:
>>> Dear community,
>>> I want to export a QGIS project. In this project there are a few
>>> layers (the path for each layer is set according to where the data
>>> is saved on my computer). I can open the project on my computer and
>>> all the layers are available.
>>> But when I send the project (and all the data for the layers -
>>> everything is in one repository) to a colleague, he can not view the
>>> layers (because the paths are still set according to my computer).
>>> One can fix this in a few minutes by setting up the correct paths,
>>> but this is very annoying. And once the paths are set correctly, all
>>> the symbology from the layer properties is lost (or reset to some
>>> standard).
>>> Is there a way to save a QGIS project and all the related data as
>>> one file (so that another person, who opens this file on its own
>>> computer, does not have to set up all the paths and edit the
>>> symbology)?
>> Try the QConsolidate plugin from Alex Bruy:
>> https://github.com/alexbruy/qconsolidate
>> available from his plugin repo (or github)
>> https://plugins.bruy.me/qconsolidate.html
>> It is also possible to export your data to an geopackage yourself, as
>> you can also save symbology for layers into a geopackage, and..., wel
>> you would need to sent 2 files then: the gpkg with you data+symbology
>> and your QGIS project file
>> (was there a plugin to write your projectfile into a gpkg?)
>> HTH
>> Regards,
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201007/e98494ee/attachment.html>
