[Qgis-user] Missing DLLs for processing standalone console tool
johnrobot
johnrobot at gmail.com
Sat Oct 10 08:35:34 PDT 2020
Hi
I managed to get qgis_process working for running an algorithm, for example
using
qgis_process run native:dissolve --FIELD="[]"
--INPUT="C:\Eget\GIS\Geodata\Översiktskartan\ak_riks.shp"
--OUTPUT="C:\Eget\GIS\Geodata\Översiktskartan\ak_riks_dissolved.shp
However, I struggle a bit with running a model. When I try
qgis_process run
C:\Users\johnr\AppData\Roaming\QGIS\QGIS3\profiles\default\processing\models\Test.model3
I get
ERROR: The following mandatory parameters were not specified
Ytor: Ytor
native:dissolve_1:Resultat: Resultat
What do I need to specify? Not totally obvious to me. The paths to input and
output data sets are already defined in the model. I have not found any
examples of how to run a model.
Magnus
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
