[Qgis-user] QGIS and G suite integration
Greg Troxel gdt at lexort.com
Mon Oct 12 06:31:27 PDT 2020
Sarah Way <data at phbg.org> writes:
> By following Layer/Add Layer/Add Vector Layer, I have seen the Source Type
> 'Protocol' which includes an option for Google Cloud. However G Suite is
> not the same as Google Cloud and therefore I do not have details for the
> required 'Bucket or container' and 'Object key' fields.
> If I choose HTTP(S) Source Type from the 'Type' drop down menu, will this
> enable me to see and choose my layers stored in G Suite?
It sounds like you have "network drive" for storage that is a regular
filesystem.  I would suggest that you mount that drive so it appears in
your computer's local filesystem and then use a pathname.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201012/84b6b90a/attachment.sig>
