[Qgis-user] Problem filtering table on columns with NULL values
chris hermansen clhermansen at gmail.com
Thu Oct 15 07:56:58 PDT 2020
Bernd and list,
On Thu, Oct 15, 2020 at 5:18 AM Bernd Vogelgesang <bernd.vogelgesang at gmx.de>
wrote:
> Hi,
> just hit a problem when working with a table from an .ods file.
> To work with the data, I have to exclude some values from a field, where
> some entries also have NULL values.
> When I now filter on the value I do not need ("field" != 'xyz'), also
> the rows with  NULL values in that field are filtered out, which is not
> what I want.
In databases that support NULL values it's customary to use "IS NULL"
rather than "= NULL".   The rationale is that a boolean expression
involving NULL values can't be true nor false since the meaning of NULL is
"unknown".
> As I do not want to "invent" data for those rows just to make it work, I
> wonder if this is a bug or if there is a workaround for this problem.
I just tried this with the QGIS select calculator (IS NULL) and it seems to
work fine there.
Chris Hermansen · clhermansen "at" gmail "dot" com
C'est ma façon de parler.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201015/17f7b618/attachment.html>
