[Qgis-user] Problem filtering table on columns with NULL values
Nicolas Cadieux njacadieux.gitlab at gmail.com
Thu Oct 15 09:58:37 PDT 2020
Try
"field" IS NOT NULL OR "field" != 'xyz'
Nicolas
On 2020-10-15 12:12 p.m., Bernd Vogelgesang wrote:
> Hi Chris,
> I'm a bit confused: I just stated, that I use a filter !='xyz', but not
> only these rows are ommited, but also those with NULL values.
> I do not try to filter for NULL, I just want the query to NOT filter
> them out.
> So what I can do to keep the NULLs and just get rid of the xyz?
> Cheers,
> Bernd
> On 15.10.20 16:56, chris hermansen wrote:
>> Bernd and list,
>> On Thu, Oct 15, 2020 at 5:18 AM Bernd Vogelgesang
>> <bernd.vogelgesang at gmx.de>
>> wrote:
>>> Hi,
>>> just hit a problem when working with a table from an .ods file.
>>> To work with the data, I have to exclude some values from a field,
>>> where
>>> some entries also have NULL values.
>>> When I now filter on the value I do not need ("field" != 'xyz'), also
>>> the rows with  NULL values in that field are filtered out, which is not
>>> what I want.
>> In databases that support NULL values it's customary to use "IS NULL"
>> rather than "= NULL".   The rationale is that a boolean expression
>> involving NULL values can't be true nor false since the meaning of
>> NULL is
>> "unknown".
>>> As I do not want to "invent" data for those rows just to make it
>>> work, I
>>> wonder if this is a bug or if there is a workaround for this problem.
>> I just tried this with the QGIS select calculator (IS NULL) and it
>> seems to
>> work fine there.
> Qgis-user mailing list
