[Qgis-user] QGIS and SAGA 7.3.0
Nick Hopton
nhopton at gmail.com
Sun Oct 18 11:57:56 PDT 2020
Hi berndv,
I thought we might be getting somewhere with your last suggestion, I made
the changes you mentioned and the SAGA NextGen tools duly appeared. I then
tried to run the SAGA Simple filter on a one-metre DTM, but this failed with
the message 'Unknown option 'MODE''. This is a step forward of course, I'd
not managed QGIS/NexGen to recognise SAGA at all before this. Here's part of
the output from the log:
2020-10-18T19:22:34 INFO SAGA execution commands
io_gdal 0 -TRANSFORM 1 -RESAMPLING 3 -GRIDS
"/tmp/processing_LzwXIT/b240a8bf0bac43518ec759524cb8b9d0/DTMSU5565P107172019012320190325.sgrd"
-FILES
"/home/nick/Desktop/bucklebury_common/P_10717/DTM_SU5565_P_10717_20190123_20190325.tif"
grid_filter "Simple Filter" -INPUT
-MODE 0 -METHOD 0 -RADIUS 25 -RESULT
"/tmp/processing_LzwXIT/a2d7f23262044c1faa1105e743070c85/RESULT.sdat"
2020-10-18T19:22:36 INFO SAGA execution console output
____________________________
SAGA Version: 7.3.0
library path: /usr/lib/x86_64-linux-gnu/saga/
library name: libio_gdal
library : io_gdal
tool : Import Raster
identifier : 0
author : O.Conrad (c) 2007 (A.Ringeler)
processors : 12 [12]
Parameters
Grids: No objects
Files:
Multiple Bands Output: automatic
Select from Multiple Bands:
Transformation: true
Resampling: B-Spline Interpolation
loading:
Driver: GTiff
Bands: 1
Rows: 5000
Columns: 5000
loading: DTM_SU5565_P_10717_20190123_20190325
SAGA Version: 7.3.0
library name: libgrid_filter
library : grid_filter
tool : Simple Filter
identifier : 0
author : O.Conrad (c) 2003
I'm not entirely sure where I go from here!
All the best,
Nick.
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
