[Qgis-user] Clipping and keeping RGB scale
Mauricio Tecles mtecles at yahoo.com.br
Tue Oct 20 12:14:13 PDT 2020
Hi! I am new to GIS processing.
I need to cut large RGB composed satellite images in patches(5760mx5760m). The way I know to do that in QGIS is by"Raster->Extraction->Clip Raster by extent", or by batch fileon the "OSGeo4W Shell" console. I have to extract about 400 patchesfrom 4 or 5 RGB composed satellite images.
The problem is that each extracted patch ends up with its own RGBscale and I must manually correct each one of the 400 to the original min andmax for the three bands. The program that will use the patches will put themtogether as one flies over then, so they must have the same visual color aspectas they had as part of the large image.
 I have tried:
gdal_translate -projwin 417220.0 7424030.0 422980.0 7418270.0SomePanRGB.tif SomePatch.tif
and
gdal_translate -projwin 417220.0 7424030.0 422980.0 7418270.0 -scale_1 114 721114 721 -scale_2 152 568 152 568 -scale_3 223 620 223 620 SomePanRGB.tifSomePatch.tif
 without any difference. I found very lite information on -scale_bn, ifit is any good to what I want.
Is there a way to extract (clip) the patches without changing the minand max of each band (RGB)?
QGIS version: 3.10.10-A Coruña (LTR)
OTB-7.0.0-Win64
Windows 10 Home Single Language 64 bits
8GB RAM
Thank you!
Mauricio
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201020/18f2efca/attachment.html>
