[Qgis-user] Fitting an image to the paper to export
Mauricio Tecles mtecles at yahoo.com.br
Tue Oct 20 13:00:17 PDT 2020
I havelearned to export a square image from QGIS reading some Howto of making a sceneryfor a program. I used to do that, but for some reason, probably some Windows 10update, the process does not work anymore.
To have theimage exported without any border (blank margin), I used the following process:
Zoom to layer
Crtl-P (print)
Selectprinter – I have no physical printer, so I used to select Microsoft XPSDocument Writer – maybe this is the problem now, after some Windows update.
Page setup:select “size defined by user”
Add a newmap to layout
Itemproperties -> Extents: set X min, Y min, X max, Y max
Layout:Resize layout (all margins are set to 0)
Layout->Exportas Image…
I cannot dothat anymore, the paper size is kept A4 (which is rectangular) even selecting “sizedefined by user”, changing the extents and resizing has no effect.
QGISversion 3.10.10-A Coruña, Windows 10 Home Single Langage 64 bits
Any hints?Can someone help me?
Thank you,
Mauricio
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201020/795400f8/attachment-0001.html>
