[Qgis-user] Have QGIS prompt for profile to use everytime ?
Raymond Nijssen r.nijssen at terglobo.nl
Wed Oct 21 05:00:12 PDT 2020
Hi Lars,
I don't think you can. You can make a startup.py script that runs every
time you start QGIS, but it sits in your profile folder. So when QGIS
runs it, QGIS must already be aware of the profile that is being used.
Also, changing the profile needs a QGIS restart, so it seems QGIS cannot
change profile anymore while running.
Maybe you can make a small python (pyqt?) script that displays a dialog
with profile name picker and does a "qgis --profile NAME" for you?
Regards,
Raymond
On 21-10-2020 13:21, Lars I. Nielsen, LIFA A/S wrote:
> Hi list.
> If I have multiple profiles defined, is it possible to have QGIS prompt
> me everytime for which profile to use ?
> I know that I can add “--profile NAME” to the command line, but is
> looking for a way to avoid having multiple start icons.
> Med venlig hilsen
> GIS-kons., FME+Python Certified Professional
> Geoinformatik
> *T*
> 6313 6800
> lin at lifa.dk
> *D*
> 6313 6849
> *W*
> www.lifa.dk <http://www.lifa.dk>
> *M*
> *CVR*
> 20937289
> <https://www.linkedin.com/company/lifa-a-s/>
> Følg os på LinkedIn og læs de seneste nyheder fra LIFA A/S
> Qgis-user mailing list
