[Qgis-user] Have QGIS prompt for profile to use everytime ?
Raymond Nijssen r.nijssen at terglobo.nl
Wed Oct 21 08:18:05 PDT 2020
This script works for me. But I'm not all sure about the way I start a
new process for QGIS and quit the python script. I think ending the
command with an "&" only works on unix kind of systems..
import sys
import os
from PyQt5.QtWidgets import QApplication, QWidget, QVBoxLayout,
QComboBox, QPushButton
# adjust these to your setup:
qgis_bin = '/home/raymond/git/QGIS/build-master/output/bin/qgis'
profile_path = '/home/raymond/.local/share/QGIS/QGIS3/profiles'
def run_qgis():
     profile_name = cb.currentText()
     cmd = f'{qgis_bin} --profile {profile_name} &'
     #print(cmd)
     w.close()
     os.system(cmd)
app = QApplication(sys.argv)
w = QWidget()
w.setWindowTitle('Choose QGIS profile')
l = QVBoxLayout()
cb = QComboBox()
for fn in os.scandir(profile_path):
     if fn.is_dir():
         cb.addItem(fn.name)
l.addWidget(cb)
btn = QPushButton('Run QGIS')
btn.clicked.connect(run_qgis)
l.addWidget(btn)
w.setLayout(l)
w.show()
sys.exit(app.exec_())
On 21-10-2020 14:00, Raymond Nijssen wrote:
> Hi Lars,
> I don't think you can. You can make a startup.py script that runs every
> time you start QGIS, but it sits in your profile folder. So when QGIS
> runs it, QGIS must already be aware of the profile that is being used.
> Also, changing the profile needs a QGIS restart, so it seems QGIS cannot
> change profile anymore while running.
> Maybe you can make a small python (pyqt?) script that displays a dialog
> with profile name picker and does a "qgis --profile NAME" for you?
> Regards,
> Raymond
> On 21-10-2020 13:21, Lars I. Nielsen, LIFA A/S wrote:
>> Hi list.
>> If I have multiple profiles defined, is it possible to have QGIS
>> prompt me everytime for which profile to use ?
>> I know that I can add “--profile NAME” to the command line, but is
>> looking for a way to avoid having multiple start icons.
>> Med venlig hilsen
>> GIS-kons., FME+Python Certified Professional
>> Geoinformatik
>> *T*
>> 6313 6800
>> lin at lifa.dk
>> *D*
>> 6313 6849
>> *W*
>> www.lifa.dk <http://www.lifa.dk>
>> *M*
>> *CVR*
>> 20937289
>> <https://www.linkedin.com/company/lifa-a-s/>
>> Følg os på LinkedIn og læs de seneste nyheder fra LIFA A/S
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
