[Qgis-user] Have QGIS prompt for profile to use everytime ?
Fernando M. Roxo da Motta petro at roxo.org
Wed Oct 21 14:31:38 PDT 2020
On Wed, 21 Oct 2020 17:18:05 +0200, Raymond Nijssen
<r.nijssen at terglobo.nl> wrote:
> This script works for me. But I'm not all sure about the way I start
> a new process for QGIS and quit the python script. I think ending the
> command with an "&" only works on unix kind of systems..
  Perhaps the 'run()' method of subprocess module can be a more
suitable answer:
  https://docs.python.org/3/library/subprocess.html
  HTH.
> import sys
> import os
> from PyQt5.QtWidgets import QApplication, QWidget, QVBoxLayout,
> QComboBox, QPushButton
> # adjust these to your setup:
> qgis_bin = '/home/raymond/git/QGIS/build-master/output/bin/qgis'
> profile_path = '/home/raymond/.local/share/QGIS/QGIS3/profiles'
> def run_qgis():
>      profile_name = cb.currentText()
>      cmd = f'{qgis_bin} --profile {profile_name} &'
>      #print(cmd)
>      w.close()
>      os.system(cmd)
> app = QApplication(sys.argv)
> w = QWidget()
> w.setWindowTitle('Choose QGIS profile')
> l = QVBoxLayout()
> cb = QComboBox()
> for fn in os.scandir(profile_path):
>      if fn.is_dir():
>          cb.addItem(fn.name)
> l.addWidget(cb)
> btn = QPushButton('Run QGIS')
> btn.clicked.connect(run_qgis)
> l.addWidget(btn)
> w.setLayout(l)
> w.show()
> sys.exit(app.exec_())
> On 21-10-2020 14:00, Raymond Nijssen wrote:
> > Hi Lars,
> > I don't think you can. You can make a startup.py script that runs
> > every time you start QGIS, but it sits in your profile folder. So
> > when QGIS runs it, QGIS must already be aware of the profile that
> > is being used. Also, changing the profile needs a QGIS restart, so
> > it seems QGIS cannot change profile anymore while running.
> > Maybe you can make a small python (pyqt?) script that displays a
> > dialog with profile name picker and does a "qgis --profile NAME"
> > for you?
> > Regards,
> > Raymond
> > On 21-10-2020 13:21, Lars I. Nielsen, LIFA A/S wrote:
> >> Hi list.
> >> If I have multiple profiles defined, is it possible to have QGIS
> >> prompt me everytime for which profile to use ?
> >> I know that I can add “--profile NAME” to the command line, but is
> >> looking for a way to avoid having multiple start icons.
> >> Med venlig hilsen
> >> GIS-kons., FME+Python Certified Professional
> >> Geoinformatik
> >> *T*
> >> 6313 6800
> >> lin at lifa.dk
> >> *D*
> >> 6313 6849
> >> *W*
> >> www.lifa.dk <http://www.lifa.dk>
> >> *M*
> >> *CVR*
> >> 20937289
> >> <https://www.linkedin.com/company/lifa-a-s/>
> >> Følg os på LinkedIn og læs de seneste nyheder fra LIFA A/S
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
  Roxo
---------------- Non luctari, ludare -------------------+ WYSIWYG
Fernando M. Roxo da Motta <petro at roxo.org>              | Editor?
Except where explicitly stated I speak on my own behalf.|  VI !!
                PU5RXO                                  | I see text,
------------ Quis custodiet ipsos custodes?-------------+ I get text!
