[Qgis-user] get_feature_by_id crashing
Paul Wittle paul.wittle at dorsetcouncil.gov.uk
Thu Oct 22 04:03:27 PDT 2020
Has anyone experienced QGIS crashing out when trying to use get_feature_by_id within a layout?
I'm using 3.10.2-A Coruna and it works until I change the ID to 346 at which point QGIS just closes without any error messages.
I should point out the layer I'm looking at is an Oracle dataset with a primary key. I've also seen it happen when using the merge / split tools when editing so perhaps it is an oracle specific issue?
Trouble is there is no crash report which makes it harder to debug.
Cheers,
Paul
This e-mail and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. It may contain unclassified but sensitive or protectively marked material and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All traffic may be subject to recording and/or monitoring in accordance with relevant legislation. Any views expressed in this message are those of the individual sender, except where the sender specifies and with authority, states them to be the views of Dorset Council. Dorset Council does not accept service of documents by fax or other electronic means. Virus checking: Whilst all reasonable steps have been taken to ensure that this electronic communication and its attachments whether encoded, encrypted or otherwise supplied are free from computer viruses, Dorset Council accepts no liability in respect of any loss, cost, damage or expense suffered as a result of accessing this message or any of its attachments. For information on how Dorset Council processes your information, please see www.dorsetcouncil.gov.uk/416433
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201022/0b453d22/attachment-0001.html>
