[Qgis-user] Qgis 3.10 Plugin resources.qrc
Raymond Nijssen r.nijssen at terglobo.nl
Fri Oct 23 08:31:52 PDT 2020
Hi Julierme,
I see, you want the images to be used in the GUI.
Strange that a plugin reload fixes the problem and I cannot tell you
why. The only thing I noticed is that the 'import error' is trying to
import module 'resources_rc' and your python file is called
'resources.py' (and not 'resources_rc.py')
Could it be that your code at some place contains
import resources_rc
(or from resources_rc import ...)
And that that part of the code only runs at QGIS startup?? Sorry, I'm
just guessing here.
Is your code on github or something similar?
Cheers,
Raymond
PS I'm replying to the user list again, so others can help and find this
conversation in the future.
On 23-10-2020 16:45, 1520 gis wrote:
> On Fri, Oct 23, 2020 at 11:35 AM 1520 gis
> <juliermeopensourcedeveloper at gmail.com
> <mailto:juliermeopensourcedeveloper at gmail.com>> wrote:
>     Dear Raymond
>     Thank you very much for your reply. As you can see from
>     resources.qrc file config above, I am trying to add to logo png
>     images plus the plugin icon. I am doing this straight from Qt
>     Designer. I am adding three pixmap in three different labels. Either
>     choose Resource or choose File  and after that running  <pb_tool
>     compile> and <pyrcc5 -o resources.py resources.qrc> keeps showing an
>     error message ModuleNotFoundError: No module named 'resources_rc'
>     after qgis restart.
>     However if I run qgis Reload Plugin, my plugin shows up.
>     I appreciated your time. I will send a video attached.
>     On Fri, Oct 23, 2020 at 10:27 AM Raymond Nijssen
>     <r.nijssen at terglobo.nl <mailto:r.nijssen at terglobo.nl>> wrote:
>         Hi Julierme,
>         You need(ed) to convert the .qrc file to a .py file with rcc. See:
>         https://doc.qt.io/qt-5/resources.html#resources-in-a-qt-for-python-application
>         But personally I'm not using it anymore, cause you can just use
>         files straight in your code and I find it easier.
>         For example, I make a toolbar button with icon this way:
>         icon = QIcon(os.path.join(self.plugin_dir, 'icon.png'))
>         self.action = QAction(icon, 'Do something', self.iface.mainWindow())
>         self.action.triggered.connect(self.run_something)
>         self.toolbar.addAction(self.action)
>         Hope it helps!
>         Raymond
>         On 22-10-2020 21:46, 1520 gis wrote:
>          > Dear all,
>          > I have created a Qgis plugin and I use three images in the
>         resources.qrc
>          > file shown below. Everything works fine before I restart
>         Qgis. If I
>          > restart Qgis, I hit an error ModuleNotFoundError: No module
>         named
>          > 'resources_rc'. And the plugin won't start. Any comment will
>         be very
>          > appreciated.
>          > Thank you for your time in advance.
>          > Kind regards
>          > Julierme
>          > <RCC>
>          > <qresource prefix="/plugins/inde" >
>          > <file>icon.png</file>
>          > <file>censipamLogo.png</file>
>          > <file>indeLogo.png</file>
>          > </qresource>
>          > </RCC>
>          > _______________________________________________
>          > Qgis-user mailing list
>          > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>          > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>          > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
