[Qgis-user] Editing Joined Tables
Charles Dixon-Paver charles at kartoza.com
Tue Oct 27 02:02:18 PDT 2020
As far as I'm aware you cannot edit external flat file tables like csv as
they are imported into a QGIS project in a read only state.
I would try exporting those tables to a database table (like a geopackage
table without geometry) and then performing the join to see if you get the
desired result.
On Tue, 27 Oct 2020 at 10:03, Springfield Harrison <stellargps at gmail.com>
wrote:
> Hello All:
> Using version 3.10.10, I have joined two MS Excel files: Positions.csv
> and catalogue.xls using a common field called Tag. This is a tree
> inventory project.
> All is well except I cannot edit either table from within QGIS. I need
> to create some new positions manually and generally update the tables
> continuously.
> In the Join dialogue, I have selected Enable Editing but it has no effect.
> I feel that different file types or a different procedure may facilitate
> this process but am exhausted from trying so many blind alleys.
> Is there a trick to being able to edit joined tables?
> Thanks very much . . . .
> Cheers, Springfield Harrison, British Columbia
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201027/40d134f2/attachment.html>
