[Qgis-user] no package for ubuntu groovy gorilla
Frank Sokolic sokolic at worldonline.co.za
Tue Oct 27 04:28:54 PDT 2020
Hi Fernando,
I tried your suggested edit of the source file and it gives dependency
errors.
"The following packages have unmet dependencies.
  libqgis-app3.16.0 : Depends: libgsl23 (>= 2.5) but it is not installable
  libqgis-core3.16.0 : Depends: libprotobuf-lite17 but it is not installable
  qgis-plugin-grass : Depends: grass-core but it is not going to be
installed
                      Depends: grass782 but it is not installable
  qgis-providers : Depends: qtbase-abi-5-12-8 but it is not installable
E: Unable to correct problems, you have held broken packages."
Not sure what to do except wait until packages are available for groovy.
Regards, Frank.
On 2020/10/26 16:03, Fernando M. Roxo da Motta wrote:
> On Mon, 26 Oct 2020 15:19:01 +0200, Frank Sokolic
> <sokolic at worldonline.co.za> wrote:
>> Hi Reginald,
>> I've got the same problem and had to boot into Windows to continue
>> using QGIS this morning. I had QGIS 3.16 installed on Ubuntu and it
>> was removed during the upgrade to Groovy.
>    Hi all,
>    As a temporary circumvention, you may try to edit the source file
> (inside /etc/apt/sources.list.d/) and change the distro from groovy to
> focal:
> deb [arch=amd64] http://qgis.org/debian focal main
>    It is possible that no dependency issue show up.
>    HTH
>> Regards, Frank.
>> On 2020/10/26 13:29, Reginald wrote:
>>> Hi,
>>> I have recently upgraded to ubuntu 20.10 but I noticed that the
>>> QGIS version that was installed (3.14.16) was removed during the
>>> upgrade. When I activated the QGIS repo and adjusted the settings I
>>> was still out of luck. I see that
>>> "https://ubuntu.pkgs.org/20.10/qgis-amd64/" contains no package. In
>>> groovy gorilla I can install QGIS 3.10 but when I want to do this
>>> there is a dialog that pops up that says that postgis has to be
>>> removed. As I don't want my postgresql database to be altered I
>>> wonder if anyone can tell me when there will be a package for
>>> groovy gorilla.
>>> Regards,
>>> Sent from:
>>> http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
>>> _______________________________________________ Qgis-user mailing
>>> list Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Qgis-user mailing list
>    Roxo
