[Qgis-user] Editing Joined Tables
Springfield Harrison
stellargps at gmail.com
Wed Oct 28 01:39:48 PDT 2020
Hello Charles & Sebastian,
Thanks very much for your suggestions. I did try the Geopackage but it
seems much less convenient for my needs than shapefiles or CSV files. I
didn't try the xlsx option as I require a CSV table as the primary table
in the join (to import UTM coordinates). Other spreadsheet formats do
not trigger the X/Y georeferencing options found in the delimited text
file type.
I need to frequently add UTM positions to the primary table plus make
manual edits to it so it needs to be a shapefile. However, with care, I
can copy and paste new UTM records from a CSV file into the primary
shapefile.
Anyway, thanks again, your suggestions helped me along . . . . .
Cheers, Springfield
On 10/27/20 09:14, Sebastian Gutwein wrote:
> I have found that CSV layers are not editable but .xlsx layers are. I
> just tried editing a joined field in 2 .xslx layers and it worked if I
> have upsert on edit checked. QGIS 3.14.16
> On Tue, Oct 27, 2020 at 5:02 AM Charles Dixon-Paver
> <charles at kartoza.com <mailto:charles at kartoza.com>> wrote:
> As far as I'm aware you cannot edit external flat file tables like
> csv as they are imported into a QGIS project in a read only state.
> I would try exporting those tables to a database table (like a
> geopackage table without geometry) and then performing the join to
> see if you get the desired result.
> On Tue, 27 Oct 2020 at 10:03, Springfield Harrison
> <stellargps at gmail.com <mailto:stellargps at gmail.com>> wrote:
> Hello All:
> Using version 3.10.10, I have joined two MS Excel files:
> Positions.csv
> and catalogue.xls using a common field called Tag. This is a tree
> inventory project.
> All is well except I cannot edit either table from within
> QGIS. I need
> to create some new positions manually and generally update the
> tables
> continuously.
> In the Join dialogue, I have selected Enable Editing but it
> has no effect.
> I feel that different file types or a different procedure may
> facilitate
> this process but am exhausted from trying so many blind alleys.
> Is there a trick to being able to edit joined tables?
> Thanks very much . . . .
> Cheers, Springfield Harrison, British Columbia
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201028/22a3fddb/attachment.html>
