[Qgis-user] Problems Processing Toolbox
Peter Petrik peter.petrik at lutraconsulting.co.uk
Sun Sep 6 23:23:30 PDT 2020
Hi, there was a bug on MacOS where the window was not closed immediately,
but taken to the background. Can you try to minimize manually all the
windows to see if your lost QGIS windows is not there?
Best,
Peter
On Fri, Sep 4, 2020 at 9:29 PM José Carlos Guerrero Antúnez <
jcgantunez at gmail.com> wrote:
> Hi,
> I am having problems with the Processing toolbox.
> For example, I have several rasters and want to use the GDAL/raster
> miscellaneous/Merge tool.
> When I open this tool, in Input layers, select Multiple selection for all
> rasters, click on the "Select all" button and when I click on the "OK"
> button the window closes unexpectedly.
> This is happening to me with other tools that I use in the Processing
> Toolbox.
> On the other hand, this process can be executed without problems on
> version 2.18.
> I'm working on version 3.10.9-A Coruña, on MacOS Catalina.
> Any help would be very appreciated.
> Best,
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200907/1329b371/attachment.html>
