[Qgis-user] Mac computer configuration
RMG reikogoodwin at gmail.com
Wed Sep 9 15:40:28 PDT 2020
Hello Donal,
I think I now know which one I want. Thanks for your help.
Best wishes,
Reiko Matsuda Goodwin
Comoé Monkey Project <https://www.facebook.com/ComoeMonkeyProject/>
Guenon Conservation Community
<http://facebook.com/GuenonConservationCommunity/>
On Wed, Sep 9, 2020 at 10:04 AM RMG <reikogoodwin at gmail.com> wrote:
> Hello Donal and list,
> Many thanks for asking. Below is the info:
> Model Name: MacBook Pro
>       Model Identifier: MacBookPro12,1
>       Processor Name: Intel Core i5
>       Processor Speed: 2.9 GHz
>       Number of Processors: 1
>       Total Number of Cores: 2
>       L2 Cache (per Core): 256 KB
>       L3 Cache: 3 MB
>       Hyper-Threading Technology: Enabled
>       Memory: 8 GB
>       Boot ROM Version: 192.0.0.0.0
>       SMC Version (system): 2.28f7
> Apple SSD Controller:
>       Vendor: Apple
>       Product: SSD Controller
>       Physical Interconnect: PCI
>       Link Width: x4
>       Link Speed: 5.0 GT/s
>       Description: AHCI Version 1.30 Supported
> APPLE SSD SM0512G:
>       Capacity: 500.28 GB (500,277,790,720 bytes)
>       Model: APPLE SSD SM0512G
>       Revision: BXW1SA0Q
>       Native Command Queuing: Yes
>       Queue Depth: 32
>       Removable Media: No
>       Detachable Drive: No
>       BSD Name: disk0
>       Medium Type: Solid State
>       TRIM Support: Yes
>       Partition Map Type: GPT (GUID Partition Table)
>       S.M.A.R.T. status: Verified
> Best wishes,
> On Wed, Sep 9, 2020 at 5:05 AM Donal Hunt <donal.hunt at gmail.com> wrote:
>> Can you provide the following information from the command line (run
>> these commands and paste the output):
>> *$* system_profiler SPHardwareDataType
>> *$* system_profiler -detailLevel mini SPSerialATADataType SPParallelATADataType
>> ** you may want to remove/redact the "Serial Number (system)" and
>> "Hardware UUID" values before emailing.*
>> That will provide some information on your existing system and disks
>> which will make it easier to determine what appropriate replacements are
>> needed. Normally, I would look at CPU performance, amount of RAM and disk
>> speeds (HDD vs SSD vs NVMe makes a huge difference).
>> Hope that helps!
>> Donal
>> On Wed, 9 Sep 2020 at 02:00, RMG <reikogoodwin at gmail.com> wrote:
>>>  Hello QGIS users on Macs,
>>> I would like advice on purchasing a new Mac. My Mac is 5 years old and
>>> cannot handle heavy-duty QGIS procedures. I process many satellite images
>>> and some vector files with 30 m grids have millions of features, for
>>> example. To process anything is taking too long. I know there has been a
>>> discussion on ARMS hardware, but that seems a few years away. So right now,
>>> what would you recommend? I plan to partition the hard drive to handle
>>> ArcGIS as well. I do not think I can afford a dream machine like Mac Pro,
>>> though. Is a Mac mini something that you guys use and recommend?
>>> Best wishes,
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200909/3fc413bf/attachment-0001.html>
