[Qgis-user] trouble with QGIS pushed the wrong key
Alexandre Neto senhor.neto at gmail.com
Thu Sep 10 18:17:37 PDT 2020
Hello Robert,
You are talking about the layers panel. Go to View > Panels > Layers, or
right-click an empty space in the toolbars and enable the Layers panel.
Best regards,
Alexandre Neto
QGIS Support
www.cooperative.net
PS: QGIS 1.7.4 is very very dated, you should consider update to QGIS 3.10
On Fri, Sep 11, 2020 at 1:31 AM Robert Peck <fossilpecker at gmail.com> wrote:
> What key did I hit?
> I have QGIS version 1.7.4-Wroclaw built against code revision 411aff6.
> QDAL/OGR Version: 1.8.1.  PostgreSQL Client Version: 8.3.10.  SpatiaLite
> Version: 2.4.0.  QWT Version: 5.2.1.  This copy of QGIS writes debugging
> output.  This binary was compiled against Qt 4.7.1, and is currently
> running against Qt 4.7.1.
> My problem.  There used to be a panel on the left of the screen which
> displayed or listed the “delimited text layers” (the CSV data sets I have
> uploaded into the program) as well as the topographic quadrangle maps I had
> open or closed at the time.  I must have hit the wrong button and the panel
> disappeared.  Could someone kindly tell me what I did and how to get the
> panel back so that I know what to do next time I hit the wrong key?  Thank
> you.
> Bob
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200911/9b9c3742/attachment.html>
